Fueling Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2009, 06:13 PM   #1 (permalink)
View CJCride's Photo Gallery
Canada Fueling Problem
Just came from the Shell station and it took almost 5 minutes to fill. The nozzle kept shutting off. I even switched to a different nozzle and same thing.
Got the car rustproofed yesterday.
2003 Echo 240,000Km's/125,000Mi's Automatic.
Any suggestions?
PS I did search there is a reference to a pressure/overflow tube problem, w/Corolla.
CJCride is offline   Reply With Quote
Old 11-16-2009, 04:08 AM   #2 (permalink)
jambo101's Avatar
View jambo101's Photo Gallery
Sure sounds to me like the pressure vent is now plugged up with undercoating material,if it was an oil spray it will probably correct itself after a tank or two if it was the grease application you have a bigger problem.I'd go back to CT and tell them of your new problem since their undercoating and if they are an OK franchise they will bring in the car and blow out the lines with compressed air.
jambo101 is offline   Reply With Quote
Old 11-16-2009, 10:27 AM   #3 (permalink)
Stevo_Echohb05's Avatar
Gameroom cash: $126305
View Stevo_Echohb05's Photo Gallery
Hope they don't blow it into the tank
I've seen the breather beside the filler get plugged with rust
Stevo_Echohb05 is offline   Reply With Quote
Old 11-16-2009, 05:01 PM   #4 (permalink)
Canada
Thanks Jambo, Thanks Stevo.
Daughter tells me that it did that{fill problem} for her last fillup also.
That gets the rustproofer off the hook.
I have a compressed air tank, guess while pulling the "summers" for "snows" I'll check the lines [4 including filler pipe] & blow away from the tank.
Any more wisdom is truly appreciated, thanks again.
Old 11-27-2009, 12:12 AM   #5 (permalink)
View echo987's Photo Gallery
I've had the same problem. sometimes varies depending on station. for me just changing the angle of the nozzle will make it work.
echo987 is offline   Reply With Quote
