transmission oil 2002 Echo Manual - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2009, 05:31 PM   #1 (permalink)
View dkf2's Photo Gallery
Purchased 4/07 at 76,000 miles, now 113,000. No records from previous owner. 1) How can I check the transmission oil? 2) How do I know when it needs changing? 3) Does this require a mechanic garage or can it be done at an oil change shop? 4) How often replace transmission oil on my manual transmission. Cannot find a dipstick or easy way to check level or color. Any advice would be appreciated.
dkf2 is offline   Reply With Quote
Old 11-19-2009, 07:15 AM   #2 (permalink)
View blkavalon's Photo Gallery
there is no dipstick on manual transmissions. there is a drain plug and a filler plug. first you drain all the fluid from the drain plug, and fill all the way to the top through the filler plug. its easy don't have to take it to a mechanic i would just go ahead and change for a peace of mind.
98 Avalon XLS, 91 Camry, 78 Corvette, 92 Saab 900,
05 Yamaha R6 Raven, 81 Suzuki GS 650L,
blkavalon is offline   Reply With Quote
Old 11-19-2009, 08:27 AM   #3 (permalink)
Just the advice I needed. Will do it myself. Many thanks.
Old 11-23-2009, 09:24 AM   #4 (permalink)
Stevo_Echohb05's Avatar
Gameroom cash: $126305
View Stevo_Echohb05's Photo Gallery
This is 100% correct however you should open the fill first, if you drain it and can't fill it you're screwed, plus it will drain faster
Stevo_Echohb05 is offline   Reply With Quote
Old 11-23-2009, 04:24 PM   #5 (permalink)
Additional trans oil drain info
Stevo,
Thanks. This will make it a lot easier and save me from screwing up. Df
Old 11-24-2009, 12:54 PM   #6 (permalink)
np
Old 11-27-2009, 12:00 AM   #7 (permalink)
View echo987's Photo Gallery
Make sure car is level when you change tranny fluid otherwise you might overfill or underfill.
echo987 is offline   Reply With Quote
