07 Yaris ECM clear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-18-2009, 11:46 AM   #1 (permalink)
View ty637sw's Photo Gallery
07 Yaris ECM clear
I changed the serpentine belt... it ran rough after..low idle.. threw code P0011
advanced timing issue..... I tried removing negative battery terminal twice.. runs but not smooth.... will this improve or..?? some people take both battery cables off and ground the Positive on the neg.. I dont want to do this but could I ground the Pos on some metal without worrying..?? I am not sending capacitor juice back thru the ECM... Murphys law
says something will fry..
hey experts and mechanics..what do you think??
ty637sw is offline   Reply With Quote
Old 12-21-2009, 09:18 AM   #2 (permalink)
Stevo_Echohb05's Avatar
Gameroom cash: $126305
View Stevo_Echohb05's Photo Gallery
Grounding the pos wire to the neg wire is the same as grounding it anywhere on the car, if nothing fried with 12V between them then nothing should happen with no power
This code is not related to changing the belt so you might actually have a problem. If you can check the code can you not erase it with the scanner you used?
Stevo_Echohb05 is offline   Reply With Quote
Old 12-22-2009, 02:35 PM   #3 (permalink)
View n00b's Photo Gallery
If it happened after the changing the belt then it's probably the oil control valve (behind the alternator). It's either broken or disconnected.
n00b is offline   Reply With Quote
