2000 echo need help installing low beam light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2009, 10:29 AM   #1 (permalink)
View drshawn's Photo Gallery
my low beam light is out. I need help installing. Can anybody help me? I don't have manual. I don't know how to get to light to replace.
Thanks in Advance.
drshawn is offline   Reply With Quote
Old 12-28-2009, 12:55 PM   #2 (permalink)
Stevo_Echohb05's Avatar
Gameroom cash: $126305
View Stevo_Echohb05's Photo Gallery
unplug the connector
remove light (probably held in by a wire that you depress then move)
install new light with out touching the glass part
re clip light
plug wire back in
Stevo_Echohb05 is offline   Reply With Quote
Old 12-28-2009, 01:32 PM   #3 (permalink)
re clip light
plug wire back in
This makes it sound simple. I guess I can't figure out how to get to the connector?
Old 12-29-2009, 02:06 AM   #4 (permalink)
View MzVitz's Photo Gallery
Hay dude, there's a big rubber grommet thing that covers the connector, I am unsure if you need to twist it or just pull it off, but under it is the clip/wire that holds the light bulb in place
MzVitz is offline   Reply With Quote
Old 12-29-2009, 07:40 AM   #5 (permalink)
ok, i took the rubber thing off. There was some wire plugged into something. I unplugged. Now I am on hold. The plug doesn't match the blub i bought. So I am not sure what the plug goes to. What do i do next?
Old 12-29-2009, 02:19 PM   #6 (permalink)
In that cause you may have brought the wrong bulb, you could just pull out the original bulb and take it with you to the store so you can match them up
Old 12-29-2009, 02:22 PM   #7 (permalink)
+1
Old 12-29-2009, 05:34 PM   #8 (permalink)
ok, then this is the question I should be asking:
How do I get the bulb out? That is what I am having problems with. If I can get that out, then I can get the one I bought in.
Thanks again guys.
Old 12-30-2009, 02:49 PM   #9 (permalink)
Hoping this will help....
http://autorepair.about.com/od/fixit...te_replace.htm
Otherwise just take it to your nearest mechanic and ask them to show you
Old 12-30-2009, 02:59 PM   #10 (permalink)
thanks guys. I took to a mechanic near my office and asked him how to do it. He showed me. Was a little bit more difficult that I thought, but its done and he did it for no charge at all.
