high octane fuel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-12-2010, 11:12 AM   #1 (permalink)
View shazoo's Photo Gallery
high octane fuel
hi there,
i have vitz 2003 with 1SZ-FE.want to ask if can use high actane fuel in my car?does this increas fuel economy and performance?or effect my engine performance and life ? thanks for any feed back
shazoo is offline   Reply With Quote
Old 02-12-2010, 11:53 AM   #2 (permalink)
jambo101's Avatar
View jambo101's Photo Gallery
Wont do anything except leave less money in your pocket after fill up..
Welcome to the forum
jambo101 is offline   Reply With Quote
Old 02-12-2010, 12:11 PM   #3 (permalink)
View buci's Photo Gallery
It will do absolutely nothing, neither good or bad. I wrote this when a friend of mine asked the same question how to send his money down the drain ,http://www.carinstructions.com/regular-vs-premium-gas/
buci is offline   Reply With Quote
Old 02-12-2010, 03:24 PM   #4 (permalink)
JNEG
JNEG's Avatar
Gameroom cash: $284100
View JNEG's Photo Gallery
Octane fax
Rule of thumb is to use what the manufacturer recommends; spending more on a higher octane just makes the oil companies richer than they already are! In many cases you can use a lower octane fuel, but it usually decreases performance, and should never be used if a pinging sound from your engine results from it.
JNEG is offline   Reply With Quote
Old 02-21-2010, 09:21 AM   #5 (permalink)
360ci
htwo's Avatar
View htwo's Photo Gallery
X2. Running a higher octane isn't necessary as the PCM will just alter the A/F ratio to compensate. It won't add power.
'00 Durango R/T - 183,000kms (will replace with a 2.7L I4 Highlander shortly)
'99 Taurus SE sedan - 204,500kms
'06 Pontiac G6 GT - 42,000kms
htwo is offline   Reply With Quote
Old 02-21-2010, 02:25 PM   #6 (permalink)
'95 Previa S/C AWD Driver
AlaricD's Avatar
Gameroom cash: $150452
View AlaricD's Photo Gallery
Sometimes using higher octane fuel than what the manufacturer recommends can lead to increased carbon buildup in the combustion chamber.
AlaricD is offline   Reply With Quote
Old 02-24-2010, 02:30 PM   #7 (permalink)
on full afterburner
Gameroom cash: $1349597
Originally Posted by shazoo View Post
hi there,
yes. no. no.
stick with regular.
