Toyota Belta - Engine keeps cranking after start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2010, 07:47 AM   #1 (permalink)
View nitianand's Photo Gallery
Hi all,
I have just bought a used toyota belta (a.k.a yaris) 1000cc and i am having some trouble with the starter when the engine is cold in the morning. When i turn my ignition key to start the engine, i see that the starter keeps cranking even after starting the engine. I have tried putting a new battery but the problem is still there. The only workaround i have for now is to turn off the engine while the cranking goes on, then restart again. I am fed up with this problem as no mechanic is able to understand what is going wrong. Any help will be most appreciated.
Thanks in advance.
nitianand is offline   Reply With Quote
Old 02-27-2010, 04:43 PM   #2 (permalink)
jambo101's Avatar
View jambo101's Photo Gallery
For some reason that i cant figure out this seems to be normal
jambo101 is offline   Reply With Quote
Old 03-02-2010, 11:42 AM   #3 (permalink)
No, this is not normal. The normal behaviour would be that the engine stops cranking as soon as the engine starts.
Old 03-02-2010, 08:32 PM   #4 (permalink)
Half a Bubble Off Plumb
Yaris Hilton's Avatar
View Yaris Hilton's Photo Gallery
Smile
Sometimes a starter drive will get dirty and bind, so it doesn't kick loose from the flywheel ring gear as it's supposed to immediately.
Yaris Hilton is offline   Reply With Quote
Old 03-03-2010, 04:24 AM   #5 (permalink)
jambo101's Avatar
Ooops sorry i didnt thoroughly read your post, you are definitely right the engine should stop cranking once the engine starts..
Old 03-03-2010, 09:00 AM   #6 (permalink)
I see. Is there anything you can suggest in terms of how to fix this issue. My real concern is that no electrician has even got a clue about this problem;(
Old 03-03-2010, 09:01 AM   #7 (permalink)
for info, my car has only 5000km of mileage and yet this problem!
Old 03-03-2010, 10:55 AM   #8 (permalink)
jambo101's Avatar
Any chance it could be a problem with the ignition switch?
Old 03-03-2010, 03:04 PM   #9 (permalink)
Stevo_Echohb05's Avatar
Gameroom cash: $126305
View Stevo_Echohb05's Photo Gallery
I've seen a bad starter staying engaged
-with only 5000 kms are you not still under warranty?
Stevo_Echohb05 is offline   Reply With Quote
Old 03-03-2010, 08:42 PM   #10 (permalink)
Smile
A binding starter drive is a mechanical problem. You have to take the starter off to work on it. As said above, it sounds like this car ought to still be in warranty.
Old 05-13-2010, 02:20 AM   #11 (permalink)
View wendylee's Photo Gallery
My 2010 Yaris with 1,200km on the clock has done this since I picked it up from the dealer 3 weeks ago, it happens on and off, in the mornings and afternoons.
Its going back to the dealer for the 2nd time in 2 weeks to get sorted, I will keep you posted on the outcome
Dreaming in colour.......Living in black & white
wendylee is offline   Reply With Quote
Old 07-03-2010, 09:19 AM   #12 (permalink)
View nuwan's Photo Gallery
you are right this happen to me so i took out the starter morter clean every thing and add some white grease to the release bearing no problem
i didn't pay nobody. hope this helps
nuwan is offline   Reply With Quote
