Battery not charging aft. engine wash! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2010, 07:58 PM   #1 (permalink)
View CJCride's Photo Gallery
Canada Battery not charging aft. engine wash!
Help!
03 Echo, washed engine and bay with spray cleaner and garden hose.
Started fine, after about 3 minutes of driving Battery light came on noticed headlights dimmer barely got back home.
Car is now attached to home charger @ 2 amps.
What did I short or wreck?
Update: just found the large wire to the alternator had corroded so badly that it was broken under it's insulator at the connector.
CJCride is offline   Reply With Quote
Old 04-01-2010, 10:24 AM   #2 (permalink)
RAM-Driver
denman's Avatar
View denman's Photo Gallery
Canada
You got a cheap lesson in cleaning under the hood. Never wash when the engine is hot or even warm, and then with electronics covered, including alternator, fuse box, spark modules. Spray cleaners and garden hose as you did is OK but no pressure washers should get nearer than the radiator, preferable pointed from the fan side toward outside. Glad you found an easy fix unrelated to the cleaning work.
2000 Echo, 200,000kms, aftermarket cruise control (AudioVox CCS-100), Intelligent Battery Guard (CTC), Sirius Satellite Radio, Scangage II, Garmin GPS, synthetic engine and gearbox lubes , Silicone Brake Fluid, Power Steering belt removed, delighted with the "tiny perfect car"
denman is offline   Reply With Quote
