New prob - Grind/knock when making sharp turn
This problem is driving me nuts with my '07 Yaris Sedan... Each time I turn into my driveway there's a brief grind/knock from the front end.
Here's some things I've noticed/haven't noticed:
1. Turning sharply at 90 degrees and wide turning 90 degrees produces noise grind/knock.
2. I can feel it in the floor a bit.
3. Noise isn't so bad when it's raining/wet outside.
4. Sometimes over dips in the road going straight I hear the same noise.
5. Going over large bumps (i.e. large speed bump) does NOT re-produce noise.
6. Going over medium bumps while applying the brake somewhat produces the noise.
7. Turning left and right in park or neutral does NOT re-produce noise.
Note, I recently got new steel rims (15in) and new tires, so this could be cancelled out. I have 97k on the car, original brakes/rotors, original struts/springs.
What could this be?
