Echo 2005 brake issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2010, 08:57 AM   #1 (permalink)
View rrossi's Photo Gallery
HI
I own an Echo 2005 sedan automatic with 65000KM. In the last week i noticed that when i brake at low speeds, l hear a "Tack" sound when i first apply the brake. It brakes fine except for that noise. What can the problem be?
Thanks
Robert
rrossi is offline   Reply With Quote
Old 05-25-2010, 12:38 PM   #2 (permalink)
Stevo_Echohb05's Avatar
Gameroom cash: $126305
View Stevo_Echohb05's Photo Gallery
sounds like you need to "service" the brakes, take everything apart clean and reassemble
Stevo_Echohb05 is offline   Reply With Quote
Old 05-26-2010, 03:52 PM   #3 (permalink)
soloecho2's Avatar
Gameroom cash: $101710
View soloecho2's Photo Gallery
It could be as simple as removing and ensuring the wheels are re torqued properly.
soloecho2 is offline   Reply With Quote
Old 05-31-2010, 03:58 PM   #4 (permalink)
jason_echo's Avatar
View jason_echo's Photo Gallery
I ve got a similar problem. But mine is a whisteling noise as soon as i touch the brake pedal. The noise is coming from the rear brakes...any suggestions?..im thinking its time to change the brakes at the back...
jason_echo is offline   Reply With Quote
Old 06-12-2010, 12:24 PM   #5 (permalink)
Newbie One Kanobi
ECHOKnight2000's Avatar
Gameroom cash: $664359
View ECHOKnight2000's Photo Gallery
Its either the brakes or the wheel bearings. I recently went in for my tranmission (of course two places couldn't find anything with that) but both places said I needed new wheel bearings. I didn't believe them cause its an econo car with no sound deadening so of course you'll hear tire noise or whatever. But it was the bearings cause i got the back ones replaced and its quieter. Pricey but quieter. Of course it would be more pricey if I left it alone.
THe mechanic said my rear drums were showing signs of wear, or to the point of needing replacement, but that's a little off for me.
Live faster than the speed of fear
ECHOKnight2000 is offline   Reply With Quote
Old 06-28-2010, 03:41 PM   #6 (permalink)
HI
I own an Echo 2005 sedan automatic with 65000KM. In the last week i noticed that when i brake at low speeds, l hear a "Tack" sound when i first apply the brake. The mechanic said that the pads are moving in the caliper causing the noise. He applied a silicon but a couple of days later the problem returned. What can it be ? The caliper?
Thanks
Robert
Old 07-15-2010, 07:24 PM   #7 (permalink)
Solace87's Avatar
View Solace87's Photo Gallery
You bring up an EXCELLENT point that many people overlook.
Yes these cars are going to be loud, they are small thin metaled cars with no sound deadening. Even with everything running 100% you are going to hear some things.
I once tore down a bmw 7 and that car had more insulation under one seat then an entire echo/yaris
Where I am the roads are so bad sometimes it sounds like something is failing when its not.
96 Supra
92 VR4
02 ECHO (never thought i'd see the day, but I love it!)
Solace87 is offline   Reply With Quote
