Fuse Specs - 2000 Echo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2004, 07:11 PM   #1 (permalink)
View Wild's Photo Gallery
Hi There,
I recently had my tail lights give out on my 2000 Echo. Brake, signal, and reverse lights are all still fine. I'm pretty sure it's just a blown fuse or loose wire.
Problem is I can't find the specs on what fuse is which in the fuse box under the hood. I don't have a user manual and the dealership in my area has to order on in if I want it.
Anyone have the info on which fuse is what on this model? Or if it might be something other than a fuse?
Thanks,
Wild
Wild is offline   Reply With Quote
Old 03-28-2004, 12:30 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
just the rear running lights don't work? the front running lights do? are there any side marker lights and if so do they work?
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 03-28-2004, 07:25 PM   #3 (permalink)
Lights
Yes, all the other lights on my car work except for the regular tail lights. Brake lights, reverse(white), and signals are all fine. All the front lights work as well.
Old 06-29-2007, 10:38 AM   #4 (permalink)
View olegmalkin's Photo Gallery
Did you ever figure this out? I am having similar problems on my 01 Echo. Thanks
olegmalkin is offline   Reply With Quote
Old 06-29-2007, 01:56 PM   #5 (permalink)
View n00b's Photo Gallery
If everything else works, replace the tail light bulbs.
n00b is offline   Reply With Quote
