problem filling gaz echo 2001 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-16-2010, 08:20 PM   #1 (permalink)
View nuwan's Photo Gallery
Hi , i just bought my echo 2001 4 door, hard to fill the gaz in to the gaz tank. while trying to fill up it keeps cutting.
first i thought it may be the gaz station. after try few gaz stations same result. i disconnected all the gaz filler lines and check for a blockage and did not find any blockage. all the gaz lines are ok. no damage or bent. any idea please let me know. any reply will be appriciated thanks
nuwan is offline   Reply With Quote
Old 06-16-2010, 08:41 PM   #2 (permalink)
View ed0628's Photo Gallery
Nuwan,
I had the same problem with my 1998 Camry. Removed the vent hose from the evap canister and found a spider's nest blocking the vent. The nest was white and thick. Removed the nest and problem solved. This seems to be a common problem. Don't know for sure but there may be an affinity for spiders to inhabit that space.
Hopes this helps.
ed0628
ed0628 is offline   Reply With Quote
Old 06-16-2010, 09:58 PM   #3 (permalink)
Originally Posted by ed0628 View Post
Nuwan,
Hopes this helps.
ed0628
thanks i verify every thing in the vent hose even put my air compressor all the lines are clear can it be any valve on top of the gaz tank . i will remouve my gaz tank to see if there is any valve to release the air from the tank to out side. only that cand be the problem i can think of. if some one have an idea please let me know because i have no money right now to bring it to the dealer
Old 06-17-2010, 03:37 AM   #4 (permalink)
nighthawk8's Avatar
View nighthawk8's Photo Gallery
My 97 Tercel does the same thing but only once in a while.
nighthawk8 is offline   Reply With Quote
Old 06-17-2010, 10:56 PM   #5 (permalink)
Solace87's Avatar
View Solace87's Photo Gallery
These cars are notorious for this problem. In fact its the number one complaint I hear.
Unless its a huge pain I wouldnt pay anyone to figure it out especially if its an expense you dont need.
96 Supra
92 VR4
02 ECHO (never thought i'd see the day, but I love it!)
Solace87 is offline   Reply With Quote
Old 06-26-2010, 06:55 AM   #6 (permalink)
solve my problem thanks
Old 06-26-2010, 06:58 AM   #7 (permalink)
finaly i found the problem and solved it
the broblem was the clapet in side the gas tank so i went to the scrap yard and got the tank and the canister for 150$ came home happy. instaled them no problem. now i can fill gas and the check engine light is gone i am so happy. thanks to everyone who help me with there coments
