A few general questions (Echo=my first car) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-12-2010, 03:39 PM   #1 (permalink)
View Violet's Photo Gallery
Hello,
This 2003 Echo is actually my first car, so my questions are gonna be newbie-ish:
1) I just passed the 50,000 mile mark; aside from oil changes every 3,000 miles and some kind of maintenance at 30K...what other routine things should I be doing?
2) There's a scheduled major maintenance at 60K, is that right? Does anyone know what the entails and how to avoid getting REAMED at the dealer?
3) My trunk can no longer be opened with the lock (key). I tried looking at the lock assembly...but could not figure out what would need to be lubricated...anyone else seen this?
4) I have a few chips out of the paint on the hood (less than 1 square centimeter of chips...like 5 small spots)...how much would a paint repair cost and where do you recommend this be done? Do non-dealers have the silver paint from a 2003 echo?
Thanks!
Violet is offline   Reply With Quote
Old 09-12-2010, 03:50 PM   #2 (permalink)
View scarney1988's Photo Gallery
Saving money on maintenance really depends on one thing: Will you be performing the maintenance yourself. I would recommend purchasing a owners manual and maintenance guide from your dealer. Good reference material for owners.
I believe a 60k for the echo is probably:
Oil Change
Tire Rotation
Brake inspection
Replace Engine Air filter
Replace Cabin air filter (if its equipped, not sure)
Clean and Adjust Rear brakes
Additional maintenances to consider:
Coolant Service
Transmission Service
Accessory belt Replacment (if cracked)
Inspect throttle plate and clean
Your engine has Iridium Spark plugs which are due at 120k. The echo is a fairly simple car. There is not a whole lot of maintenance for these things.
scarney1988 is offline   Reply With Quote
