Ugh, need some help guys! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-21-2010, 12:39 AM   #1 (permalink)
Solace87's Avatar
View Solace87's Photo Gallery
Ok, so I am passing the echo to my girlfriend and purchasing a z3 or z4.
Her dad said he wanted to have his friend inspect it.
After a year of TLC and some mods the car runs great. cant even feel the engine at idle! (uncommon in these cars I hear)
Well he takes it to the guy and she brings it back. We drive about 20 miles and all of a sudden its bucking at idle, missing and low RPM, all that good stuff.
So I pull over and look under the hood.
The hose going into the side of the airbox is now closed in the airbox and completely crimped. He obviously checked the airfilter and then closed the hose on it.
I pull spark plugs and cylinder one plug is covered in brown sludge. Just dripping.
Could that hose being crimped cause anything like that? also the name of that hose is escaping me, anyone know it so I can do some googling?
The thing that scares me is there was absolutely no progression to it. It went from running like a top to that in seconds.
I pulled the plugs and replaced them with some good used ones I had lying around. Its at least got to get me to work tomorrow haha
If it is a headgasket all I can say guys is the whole engine is being torn down and expect a small turbo build . I have some 9bs lying around. Would be perfect for this car. Nothing severe but to make it a little more fun
96 Supra
92 VR4
02 ECHO (never thought i'd see the day, but I love it!)
Solace87 is offline   Reply With Quote
Old 09-21-2010, 05:38 AM   #2 (permalink)
soloecho2's Avatar
Gameroom cash: $101710
View soloecho2's Photo Gallery
It most likely pulled in oil through the PCV line. After you changed the plugs is it running OK ??
soloecho2 is offline   Reply With Quote
Old 09-21-2010, 06:27 AM   #3 (permalink)
Solace87's Avatar
Hmmm I have heard of that before.
It ran an idled fine. I had to come in and go to bed though, four hours sleep last night and tonight haha.
Hopefully I make it to work :p
I have many spare plugs just in case haha. It didnt overheat on the way home so I think I will make it. Hopefully my little red light isnt just out like my high beam indicator
96 Supra
92 VR4
Old 09-21-2010, 12:51 PM   #4 (permalink)
View jmk1977's Photo Gallery
sounds like the guy my girlfriend took her car to get inspected with.
maybe he poured some bearing grease in your cylinders to give him some work?
people are assholes never put anything past them bro.
jmk1977 is offline   Reply With Quote
Old 09-21-2010, 06:05 PM   #5 (permalink)
Solace87's Avatar
Could be on purpose, wouldnt be too surprised. After the sludge burned off (im sure my Cat appreciates that) it ran great again.
96 Supra
92 VR4
Old 09-23-2010, 12:47 PM   #6 (permalink)
I would go visit that person and give him a piece of my mind.
I plan on calling the guy that fe'd up my g\f's car this afternoon.
You can clean the cat by removing it 'if possible' and cleaning it up with acetone or gasoline.
Old 09-23-2010, 02:12 PM   #7 (permalink)
jambo101's Avatar
View jambo101's Photo Gallery
If you are giving the car to your girlfriend why is it any business of her father?. i would have said the car is running fine take it or leave it,
jambo101 is offline   Reply With Quote
Old 09-23-2010, 11:18 PM   #8 (permalink)
Solace87's Avatar
Hes just protective like that is all. He pretends he knows about cars :p
Normally I would however this guy is one of her fathers best friends and in the past he has...
1 Done an oil change on her moms camry and forgot to fill it with oil again. She drove it home like that
2 Charged her sister 400 to replace the downpipe on a 96 camry. If he cared he would have welded in a new flex section, not paid for an OEM part
3 Talked her father into doing a FULL trans rebuild on my girlfriends old accord because it had a minute hesitation in one gear. The kind of hesitation I have seen go on for 50k with no problems.
And now this.
It was an honest mistake but whatever. I cleaned out everything and its running fine.
96 Supra
92 VR4
Old 07-13-2011, 08:24 PM   #9 (permalink)
View toyotaman7166's Photo Gallery
Reviving an old thread
Im just curious but would oil on cylinder 1's plug indicate a leaking head gasket? Also, isn't a head gasket relatively easy to replace? (just unbolt and remove the head and replace the gasket ...simple) Unfortunately my car has developed a hesitation. When I change gears, as soon as I shift into second it has hardly any power at all and it takes a sec or two and when the rpm's get a little higher it'll suddenly gain power like a switch had been flipped. It does that in all the gears. Its annoying but still very drivable. I just seems like the surge of power only comes after the rpm's have raised past a certain point. Cant detail the exact measure of rpm cuz as you all know the echo doesn't have a guage for that! I've considered it might be something to do with the vvti. maybe the fuel filter? who knows. but I would like some thought on the possibiliy of a leaking head gasket. anyone care to add some insight?
toyotaman7166 is offline   Reply With Quote
