Tire help! 2005 Toyota Echo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2010, 10:12 AM   #1 (permalink)
View Frazzle's Photo Gallery
Can anyone help by telling me if this tire size could fit on my 2005 Toyota Echo? They are winter tires - 195/75/14.
Thanks
Frazzle is offline   Reply With Quote
Old 11-14-2010, 04:48 PM   #2 (permalink)
View 2005RS's Photo Gallery
Thanks
Pretty sure they're too big. check out this site to see for yourself: http://www.1010tires.com/tiresizecalculator.asp
There's lots of winter tires on kijiji right now
2005RS is offline   Reply With Quote
Old 11-17-2010, 01:49 PM   #3 (permalink)
Stevo_Echohb05's Avatar
Gameroom cash: $126305
View Stevo_Echohb05's Photo Gallery
Tire Size Comparison
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
175/65-14 4.5in 11.5in 23.0in 72.1in 879 0.0%
195/75-14 5.8in 12.8in 25.5in 80.2in 790 11.1%
You should stay within 3% to not have any problems.
Stevo_Echohb05 is offline   Reply With Quote
Old 11-17-2010, 02:50 PM   #4 (permalink)
View twiki's Photo Gallery
Hi Stevo,
Like many others, I'm cheap shopping on Kijiji for winter rubber with wheels (so I can make the switch myself).
I'm familiar with the 175/65R14 designation, but how are (steel) wheels described? I've seen 14 x 6 and 14 x 5.5 used on www.1010tires.com. 14 is the diameter in inches (same as the tire), and the 6 is the width of the 'seat' in inches (and the closest measurement to this is the 175 (cm) of the tire).
Is there a metric designation for wheels?
Thanks.
Roland
Impulse Red Pearl 2003 Sedan
my first Echo
twiki is offline   Reply With Quote
Old 11-18-2010, 10:29 AM   #5 (permalink)
The rim size you need is 14X5.5 bolt pattern is 4 x 100 hub size is 54.1 and the offset is +45
jobber rims should sell for 50 - 55 $ each
OEM rims 55 - 60 each
Old 11-18-2010, 10:53 AM   #6 (permalink)
Hi Stevo,
OK, so if I were to provide someone a complete description of the wheels and tires I wanted to buy (assuming stock), it would be...
  • 175/65R14
  • 14X5.5
  • bolt pattern is 4 x 100
  • hub size is 54.1
  • offset is +45
When you think of it, it's a weird mixture of metric and imperial, both centimeters and inches used in the same specs.
BTW, what's a jobber rim? Something cheap?
Thanks.
Roland
my first Echo
Old 11-18-2010, 05:29 PM   #7 (permalink)
View tstclr's Photo Gallery
Jobber means a non-OEM part (not made by Toyota-likely made in China)
Todd
tstclr is offline   Reply With Quote
Old 11-20-2010, 06:18 PM   #8 (permalink)
View Why?'s Photo Gallery
wheel sizes just look stupid in metric.
I mean 355.6 mm x 139.7 mm is just a crazy mouthful.
the rest of the measurements are established by the manufacturers, and since the majority of them are overseas, everyone just migrated to metric.
And the 65 is a ratio. just to be different.
You can still buy tires measured in inches, but they are for older cars, when they measured them in inches for all cars.
Also, the offset can be slightly different, it does not need to be exact.
For example discount tires sell 14" steel wheels that fit these cars, but with a +39 offset instead of a +45. Oh, and they are $40.
Why? is offline   Reply With Quote
