Just bought a 2005 Echo (2D Hatchback, Manual), but the remote is dead. It comes with 2 other new remotes, but I need to re-programm them myself. The 2nd step on the instruction sheet reads "Push the Valet switch 3 times ...", but I don't know where the Valet Switch is.
The full instruction is here:
PROGRAMMING
XT-35 Transmitter for the CPX-2600 & CPX-3600
PROGRAMMING TRANSMITTER:
Enter:
1. Turn the Ignition switch
“OFF/ON” 3 TIMES and stay in ON position. Within 15 seconds,
2. Push the Valet switch 3 times (hold in on the 3rd push); when one long chirp is heard then
release the valet switch. You are now in the Transmitter programming mode.
Program:
1. Press any button on the first transmitter until the siren responds with a confirming chirp; the
first transmitter is now programmed.
2. Press any button on the second transmitter until the siren responds with a confirming chirp;
the second transmitter is now programmed.
3. Apply the same procedure to program any 3rd and 4
th transmitters.
Exit:
Turn Ignition to “OFF” position, or leave it for 15 seconds. Three long chirps will confirm
exit.
Note: If more than 4 transmitters programmed, the system will only keep the last 4 transmitters.
Thanks
