Varad scanner install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2011, 04:32 PM   #1 (permalink)
jimdiane's Avatar
View jimdiane's Photo Gallery
Canada Varad scanner install
I'm installing a LED scanner "fake alarm" on my dash. The wiring is quite simple, Black:ground, Red:power, Orange:Ignition(somewhere in the fuse box)
Does anyone know where this is located in the fuse box?
thanx
jim
jimdiane is offline   Reply With Quote
Old 01-13-2011, 07:37 AM   #2 (permalink)
View 2005RS's Photo Gallery
in my echo, the cigarette lighter is tied to the ignition/accessory circuit. if your car is the same, it would be easy to find and tap into that
2005RS is offline   Reply With Quote
Old 01-13-2011, 04:20 PM   #3 (permalink)
jimdiane's Avatar
what year is your echo?
Old 01-13-2011, 04:26 PM   #4 (permalink)
'05 hatch
Old 01-13-2011, 06:30 PM   #5 (permalink)
jimdiane's Avatar
so the ignition and the cig lighter are the same fuse?
jim
Old 01-14-2011, 08:33 AM   #6 (permalink)
jim
not exactly. if you pulled your cig lighter fuse, you wouldn't kill the ignition circuit. However, the cig lighter circuit is activated with the key turning. of course you can verify this by plugging something into the lighter socket and seeing if it's powered with or without the key
Old 01-14-2011, 04:09 PM   #7 (permalink)
jimdiane's Avatar
thanx for the info. The lighter only works with the ignition on.
I'm a little confused with the directions:
" BLACK WIRE : GROUND
RED WIRE: BATTERY POSITIVE(constant)
ORANGE: IGNITION-Ground when engine is "off" (see fuse box)"
I do not understand what the orange wire is doing
Old 01-15-2011, 09:45 AM   #8 (permalink)
so let's review.
red goes to battery positive (on at all times)
black goes to ground
orange; positive when the ignition is on (like the cigarette lighter) but ground when the key is off. okay, so you need to locate your positive cig lighter wire, and check with a multitester to see if it goes to ground when the key is shut off.
you may already know this but you do this by turning the key off, setting the multitester to continuity or resistance. touch one lead to the wire in question and the other to ground. you should get continuity or zero resistance.
it sounds like the ignition wire not only gets shut off, it gets tied to ground when the key is shut off
Old 01-16-2011, 12:00 PM   #9 (permalink)
jimdiane's Avatar
thank you
jim
