Echo Front Grill and Logo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2011, 05:46 PM   #1 (permalink)
Echo Driver
View Radioactive0110's Photo Gallery
I'm wondering how easy it would be to remove the stock grill and front toyota emblem on my 2005 Echo Hatchback? Im planning on re-painting my grill, logo, and hub caps to a dark grey semi gloss to make it look a little nicer. Anyone have any ideas if you can remove/re-install them without much difficulty?
Radioactive0110 is offline   Reply With Quote
Old 01-24-2011, 07:40 PM   #2 (permalink)
JNEG
JNEG's Avatar
Gameroom cash: $284100
View JNEG's Photo Gallery
Not sure about the '05, but I had no prob removing the grill from my '00; just a few tabs to release. I first painted mine red, and then decided silver was better suited to my black coupe.
JNEG is offline   Reply With Quote
Old 01-24-2011, 09:01 PM   #3 (permalink)
Echo Driver
Ah ok should be pretty simple then, and you could probably help me on my next question. What type of paint would you recomend for this? I was thinking spray paint should work just fine eh? And would I need to use a primer? The grill is all plastic, the other ones, as we as the logo are too.
Old 01-25-2011, 10:22 AM   #4 (permalink)
JNEG
JNEG's Avatar
I used Krylon spray paint without a primer, but did a few clear coats over that. A primer would probably work better, but any small road debris that catches will cause nicks no matter what you do. The removal of the front emblem would leave holes to fill- a PITA.
Old 01-25-2011, 11:14 AM   #5 (permalink)
Echo Driver
I never thought of clear coat but now that i do, it does make sence. I've been looking around the hood, and I cant find any bolts or pegs holding the front logo on... I kinda wanted to black it out but I would have to be able to remove it and then put it back on.
Old 01-25-2011, 12:06 PM   #6 (permalink)
JNEG
JNEG's Avatar
I thought that I read somewhere about it being rivited it on, but I might have misread. If it's like the Toyota logo (print) on the back of my car it can easily be removed with dental floss.
Old 01-25-2011, 01:37 PM   #7 (permalink)
Echo Driver
Yeah that's what I've been told also, but i can't seem to find where it's mounted.
Old 01-30-2011, 07:32 PM   #8 (permalink)
JNEG
JNEG's Avatar
Did you manage to remove the front logo? You could try to work it off with the floss and see what happens... How were you going to black it out?
Old 01-30-2011, 08:33 PM   #9 (permalink)
Echo Driver
I was planning on ether painting it black or the same color as my grill once I repaint that.
