Engine Detailing - Engine noise? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2011, 04:04 AM   #1 (permalink)
View s1l3nced's Photo Gallery
OK I've made a video.
I've used a degreaser and then I used the finish on it to give it a glossy shine, however I'm paranoid (as usual) that I may have damaged something (I know, this is probably such a waste of a question but I'm paranoid so what do you expect?). Can you tell by this noise if the engine sounds normal, including belts..
Again I know this is retarded, it's 5am and I need to sleep >_< Thanks everyone.
s1l3nced is offline   Reply With Quote
Old 01-29-2011, 06:51 AM   #2 (permalink)
vic benson's Avatar
Gameroom cash: $142500
View vic benson's Photo Gallery
It is hard to tell from the video. The hissing is usually from the throttle body. Check that all of the hoses are connected. Try using a spray lubricant on the pully locations at the alternator. Take it for a drive to see if it runs ok. Other than that it looks and sounds normal. Engine compartments are harsh environments and are designed to take a certain amount of weather related abuse. I have never had eny problems with washing engines. I have simply taken them to the car wash and use the high pressure soap and then the high pressure rinse to clean them. Then I take them home and use my small compressor to blow dry them.
vic benson is offline   Reply With Quote
Old 01-29-2011, 06:55 AM   #3 (permalink)
vic benson's Avatar
I have looked at the video several times and it may be my imagination but the fuel line look kinked. Make sure all of the lines are not kinked.
Vic
Old 01-29-2011, 03:49 PM   #4 (permalink)
black powder's Avatar
View black powder's Photo Gallery
engine sounds normal ..
black powder is offline   Reply With Quote
The Following User Says Thank You to black powder For This Useful Post:
s1l3nced (01-29-2011)
Old 01-29-2011, 04:33 PM   #5 (permalink)
vic benson's Avatar
i listened to mine this afternoon and yours is totally normal.
vic
The Following User Says Thank You to vic benson For This Useful Post:
Old 01-29-2011, 05:03 PM   #6 (permalink)
vic
Thanks. Your help as always is greatly appreciated.
