I have to replace the front wheel bearing on my 2002 echo. I have to buy the right size socket to take off the axle nut. What size and type of socket do I need for this? Will a 1/2 inch drive 12 point work and if so, what mm would it be? Thanks.
This is really old but doesn't appear to have been answered: my 2000 Echo takes a 12pt 30mm socket on the axle nut. It'll take over 200 lb-ft torque to loosen so do it before you raise the car, wheel still on the ground, E-brake on, jack in place ready to lift. The main trick is to push out the old bearings and press in the new ones without damage. I did it with about $350 worth of new press (a 3-ton arbor press) and bearing separators, but I would recommend most to take the steering knuckle to a garage or machine shop. You still save a bundle by doing the on-car work and getting the knuckle done over-the-counter,
2000 Echo, 200,000kms, aftermarket cruise control (AudioVox CCS-100), Intelligent Battery Guard (CTC), Sirius Satellite Radio, Scangage II, Garmin GPS, synthetic engine and gearbox lubes , Silicone Brake Fluid, Power Steering belt removed, delighted with the "tiny perfect car"
I'm looking into removing the axle nut to get to the drive shafts, tranny, etc...
Are these nuts truly non-reusable parts? Is there a trick to be able to re-use these, or do you know how much new ones would be?
I reused mine; the nut has a sleeve extension that is notched (staked) with a chisel into a large groove in the axle after the nut is torqued. I carefully "unstaked" mine with a small round punch driven along the bottom of the axle groove to lift up the notch in the axle nut without distorting it. Then when reinstalling I simply torqued the nut and staked it like new. A garage wouldn't dare do that, but on my own car and many decades of wrenching experience, often on short funds or parts not available, I reuse where possible. Your mileage may vary, ...
The Following User Says Thank You to denman For This Useful Post:
