I searched through the forums and observed the following, which im planning to apply to my vehicle which was water damaged
Symptoms:
Jerking
Stalling
Hesitation
Stuttering
Engine Light on
Chokes when given gas
Check Engine light comes on
Error Codes:
p0300: random misfire
p0302: cylinder 2 misfire
P0303: Cylinder 3 misfire
P0031: o2 sensor related
P0133: intake leak
P1310: Ignitor #3 Circuit problem
p1349: Gear stuck in lean position?
Causes:
One guy drove through high water
One guy drove in rainy weather
One guys car sputters driving rain
My car was underwater essentially
Suggested Solutions:
Change Fuel Filter
Check the air filter
Use fuel injector cleaner
Clean/Change Mass Air Flow Sensor ****Most Popular Solution***
Change/Repair Oil control valve (OCV)
Reset the ECM by disconnecting the battery **Fairly Popular**
Tape up/Check/Change Throttle vacuum related hoses *So So*
Silicone spray ??????<-dont know what thats for.
Information from MSN AUTO
......Occasional problems on this vehicle are failures of the
Mass Air Flow (MAF) Sensor and the
Evaporative (EVAP) Emissions system. Problems with the MAF Sensor and EVAP system cause the Check Engine Light to illuminate. The cost to replace the MAF Sensor is estimated at $151.10 for parts and $58.50 for labor. The cost for parts to repair the EVAP system can range from $88.00 - $350.00....
