Originally Posted by toyotaman7166
Did you check all the other obvious stuff? ... When you cleaned the MAF sensor did you check the air filter? Just checked mine and it was dirty. Did you check the plugs? I would maybe clean the MAF again? Also there is a little screen filter for the VVTI that may get clogged...Not likely but possible. Its located on the left front of your motor.
Good luck
I forgot to plug the MAF connector back in. That was silly. The Echo with 236,000 miles has been running like new ever since I plugged the connector back in . So cleaning the fragile MAF sensor with electronic cleaner and a Q-tip while the battery is disconnected and had fixed this problem in the first place. It seems to occur when the air filter needs to be replaced. This a good tech tip for Toyota Echos, I think. I am not the first one to discover this simple, quick fix.
