2000 echo front end grinding - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2011, 09:18 AM   #1 (permalink)
View Elecjohn58's Photo Gallery
hi I am new to your forum and currently am looking for some insight into a problem I am having.. I have a 2000 Toyota echo with 142k miles and just recently have been having a grinding noise from the left front. I disassembled the brakes, and rotor but cannot find any reason for the noise. The rotors and pads were replaced in the fall and show no abnormal wear. Both sides about 80%. The noise started about two weeks ago. I drive 90 miles a day and except for the noise the car handles well. I even tried different tires and wheels I have and the result is the same. The bearing end play at the rotor seem to be in spec. Any enthusiasts ever experience this problem?
thanks
Elecjohn58 is offline   Reply With Quote
Old 04-09-2011, 03:11 PM   #2 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $915127
iTrader Score: 59 reviews
to ToyotaNation
I moved your thread to the proper forum. I'm sure one of our friendly members here will offer a suggestion as to what the problem is soon.
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 04-15-2011, 10:26 PM   #3 (permalink)
View finboy's Photo Gallery
sound occur driving straight, while loaded in a turn? while braking??
or all the time?
finboy is offline   Reply With Quote
Old 04-23-2011, 10:52 AM   #4 (permalink)
View 2005RS's Photo Gallery
or all the time?
I know this question has been posted a while ago, but the questions above might help you diagnose a bearing that is wearing out. They can get pretty loud
2005RS is offline   Reply With Quote
Old 04-23-2011, 06:39 PM   #5 (permalink)
RAM-Driver
denman's Avatar
View denman's Photo Gallery
Canada
Mine had a little growl on the front RHS that turned out to be a blown wheel bearing. I could feel a bit of play when I raised that corner and reefed on the wheel back and forth top to bottom and side to side. The other side was tight, zero play detectable. 2005RS got his done recently and I wrestled it out myself, so you're in the right place for advice.
2000 Echo, 200,000kms, aftermarket cruise control (AudioVox CCS-100), Intelligent Battery Guard (CTC), Sirius Satellite Radio, Scangage II, Garmin GPS, synthetic engine and gearbox lubes , Silicone Brake Fluid, Power Steering belt removed, delighted with the "tiny perfect car"
denman is offline   Reply With Quote
