2007 Yaris hatch w lighting issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-29-2011, 01:49 AM   #1 (permalink)
View Clipper6t8's Photo Gallery
Canada 2007 Yaris hatch w lighting issues
No speedometer backlight, dash lights, or lights on the gearshift panel will display with the headlights on. The only way I can see my speedometer at night is to turn the headlights off (park lights only) by having the dimmer in the off position. This makes the backlight on the speedometer very bright, which is normal. But as soon as you turn the dimmer on to activate the headlights and lights on the gearshift panel, the backlight on the speedometer disappears (when working correctly it just dims a bit), and the lights on the gearshift panel do not light up. The light on the display(same portion of display as the speedometer) that tells you your headlights are on DOES display, however, when the headlights are on. I've checked all the fuses inside the cabin under the steering wheel, and they all appear to be intact (no breakages in the distinct "M" shape). Anybody have any suggestions before a spend a fortune at a garage?
Clipper6t8 is offline   Reply With Quote
Old 04-29-2011, 12:35 PM   #2 (permalink)
thebarber's Avatar
View thebarber's Photo Gallery
post this question on yarisworld.com and hope that ctscott answers you...
thebarber is offline   Reply With Quote
Old 05-02-2011, 06:59 PM   #3 (permalink)
Thanks for the advice. Problem solved!
