Hi,
The check engine light for my Echo is lit, and my friend who scanned it got the "P1780" code, which refers to the park/neutral safety switch. He recently replaced the starter, and in the course of doing so, he had to disconnect the battery a couple of times. He also replaced the rear tail light assemblies (I bought them, but didn't know how to put them in). After all this work was done, the check engine light came on, and the left rear tail lights started acting funky - the left rear turn signal doesn't work when the brake is on, but works fine when the brake is off. Also, the left brake light doesn't work in reverse, but works fine in park or the forward gears.
With all that said, I saw this thread discussing a similar problem:
Ck Eng Light P1780
In that thread, a poster said that most of the time, this problem is due to a pinched or broken wire going from the neutral safety switch to the rear tail lights/back up lights. That thread related to a Camry. Could the same thing be happening with my car?
Thanks so much in advance for your help.
