Look for the grattings at the base of the front windshield- where your windshield wipers are. For the inner A/C in, look underneath the front right passengr/driver's dashboard. (I don't know if the Israeli model is right or left hand drive.). Basically look for the air pump/fan unit. Also at the unit, you may or may not have to replace the air filter. Our US models here tend not to have the filters, your model may have it.
I would generally spray in all vents. Doesn't even have to be a special spray, any disinfectant like lysol should do.
I am also willing to bet that you might need to clear up any clogs in the a/c drain. To test this, take your lawn hose and put water straight into the outer vent at the base the the windshield. Water should be flowing out the bottom.
Lastly, the easiest way to prevent the smell is to allow the air to vent in from the outside the last mile or so of your trip. This allows your vents to dry up and not have sitting water which will gather mold.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
Reason: Typos.
