fix for gas pumping problem
This is easy and cheap to fix. The vapor canister inlets/outlets need to be sprayed with silicone spray (a lubricant that does not damage rubber). The vapor canister is a black plastic box about 8" x 10" near the muffler. Slide the hoses off it (the ones projecting toward the rear bumper) and shove the tiny tube from a can of silicone spray in them, then spray. This will lubricate the rubber parts inside the on-off solenoid switches inside the vapor canister. Slide the hoses back on. Then turn your key two clicks in the ignition, several times. This will work the lubricant into the solenoid switches, which are activated on/off by turning the key in the ignition.
I invented this trick when my mechanic told me a secret: the solenoid switches go bad and people usually replace the whole vapor canister for $300-$400. But one guy said he completely removed his solenoid switch and rebuilt it. A lot of work, and not necessary! Silicone spray will preserve the solenoid's parts and help them work like new again.
