Ball Joint Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2011, 04:09 PM   #1 (permalink)
View Ras H's Photo Gallery
After taking the steering knuckle off of my Toyota Echo 04, I found that most of my problems were the lower ball joint. How hard is it to separate the ball joint from the control arm? I have a press, but dont want to press it the wrong way. Can I use a pitman arm tool to do this?
I think there is a snap ring, it is very rusty and dirty, trying to figure out how to push out the ball joint.
Thanks
HH
Ras H is offline   Reply With Quote
Old 05-22-2011, 07:19 PM   #2 (permalink)
UPDATE, got it out, after hamering it with a socket behind to support it.
Old 05-23-2011, 09:27 AM   #3 (permalink)
RAM-Driver
denman's Avatar
View denman's Photo Gallery
Canada
Were you able to get a ball joint replacement? I'm finding cars now where you need to replace the control arm, the ball joint being permanently attached. I was in there recently with my Echo and suspect I may be in the same boat soon.
2000 Echo, 200,000kms, aftermarket cruise control (AudioVox CCS-100), Intelligent Battery Guard (CTC), Sirius Satellite Radio, Scangage II, Garmin GPS, synthetic engine and gearbox lubes , Silicone Brake Fluid, Power Steering belt removed, delighted with the "tiny perfect car"
denman is offline   Reply With Quote
Old 05-23-2011, 09:31 AM   #4 (permalink)
I found this on ebay, but will have to try and source them locally because of time.
http://cgi.ebay.com/ebaymotors/2-FRO...Q5fAccessories
I am hoping that I will be able to find them tomorrow. I am just not sure how I will press it in without taking the control arm off.
Old 05-24-2011, 08:01 AM   #5 (permalink)
RAM-Driver
denman's Avatar
Canada
A shop would remove the CA and use a press to install the ball joint, but you might get away with using a big C-clamp or F-clamp and that socket you used to get out the old one. And maybe some heat on the CA where the joint goes in. I recently got a 3 ton arbor press to replace my ball joints, so I'll pull the CA when the time comes. The press is heavy and ugly but it paid for itself on the first wheel bearing replacement compared to the shop charge, and after doing the second bearing I'm way in the black.
Old 06-23-2011, 01:50 PM   #6 (permalink)
View tijeff's Photo Gallery
Remove CV drive axle shaft
Have a look at :
Same thing on toyota echo 2004 and toyota corola 1999
tijeff is offline   Reply With Quote
