2000 Toyota Echo engine problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2011, 04:19 PM   #1 (permalink)
View Kevlar's Photo Gallery
Canada 2000 Toyota Echo engine problem
Hi there everyone! I just signed up on this site as I believe someone here may know what's wrong with my car. It is a 2000 Toyota Echo. I had a friend hook it up to find out the trouble codes and it came up with "P1310" (Ignitor #3 Circuit problem) and also "P0303" (Cylinder 3 misfire).
After he checked the plugs and wires and did a compression test (it was at 90, but he admited that his tester wasn"t that great), the car started to feel a little more sluggish...After ahwile after driving home it felt better.
Check engine light is still on, could it be the crank shaft position sensor?
Thanks everyone in advance for your help...Any advice is welcome..
Regards,
Kevin
Kevlar is offline   Reply With Quote
Old 06-11-2011, 09:57 PM   #2 (permalink)
View 2005RS's Photo Gallery
I'd suspect the coil pack on #3 cylinder. Can you swap coil packs and see if your cylinder misfire code moves along with the swapped coil pack?
2005RS is offline   Reply With Quote
