toyota echo 2000, check engine light on problem
My car is Toyota Echo 2000 1.5L. The check engine light came on, and since I was being careful with not messing with our only family car, decided to take it to the dealer.
I was charged $542.24, but I thought I would not have to worry anymore. However, it was only a week before the light came back on. I then took it to the dealer 3 times since the 3rd time they say will have to change the charcoal cannister. They want another $440 + TAX for that. I was wrong and would suggest everyone to not take the car to a dealer.
What they did the first time -
1. Cleaned Throttle Body
2. Cleaned Mass Air Flow Sensor
3. Replaced spark plugs
4. Changed Gas Cap.
Now I am really worried to take it to any mechanic because of my financial situation and don't want to spend another $500 unless it is the last hope.
I am planning to buy used actron autoscanner and understand the problem before I take it to someone. Do you think it will help ?
Also is there a way to fix Charcoal cannister than replacing with a new one ?
Is Charcoal canister the same as Vapor canister ?
Is there anything else I can test,clean,fix on my own and get rid of the problem ?
Appreciate any advise
Thank you
Ed
