30 bucks for the oil and filter change + your mechanic's fee for a general inspection.
Whatever it costs your mechanic to perform a general inspection.
Only real thing done:
Replace engine oil and oil filter 1
Rotate tires
Replace engine air filter
Inspect the following:
Ball joints and dust covers = Mechanic will make sure there's grease and that the dust covers aren't broken
Brake lines and hoses = he's going to tug and squeeze
Brake linings/drums and brake pads/discs 3 = It's possible you may need a replacement depending on your driving.
Drive belts 4 = will tug on them
Drive shaft boots = make sure the two drive shafts are okay and still have the rubber boot on properly.
Engine coolant 5 = he'll see if you need more
Engine valve clearance 6 = no sounds when the engine is running, he's done with this check
Exhaust pipes and mountings = tug, pull, tug.
Front differential oil = pulls the dipstick for the tranny, checks, puts back
Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses = no check engine lights..done.
Fuel tank cap gasket = still a rubber gasket? yes? done.
Radiator, condenser and/or intercooler = If the A/C works...done.
Steering gear box= anything loose? no? done.
Steering linkage and boots = see above
Transmission fluid or oil = depends on your driving.
N/A on the bolts and chassis
I don't mean to over simplify, but not much is needed at 60k. My 2008 is around the same mark. I changed the oil and filter, re-oiled my K&N filter, did minor checks and called it fini. You're right about the dealor costing so much and it was very smart of you to go to an outside mechanic. You did what I tell a lot of people which is to get to know an independent mechanic well.
Ask the mechanic for a normal oil change and ask for a general look over. Be sure to bring up the tranny fluid and brake pads. There's not much else, if you've taken the car to that particular mechanic he or she should know it a bit by now. Print out this list and hand it to him, discuss it with him. Bring a box of donuts, get to know eachother.
It annoys me how dealerships get people to think they're getting so much when in reality....it's an oil change.
Lastly, cost:
So 30 for the oil change and another 50 for the inspection? Call it an even 100? The inspection is really just the labor cost of the mechanic.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
