2000 echo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2011, 06:19 PM   #1 (permalink)
View msignorelli's Photo Gallery
2000 echo
my girlfriends 2000 echo died while she was driving. it will start off of throttle body cleaner. replaced the fuel pump and still have no start. checked the fuel pressure and there is none at the fuel rail. any suggestions?
msignorelli is offline   Reply With Quote
Old 07-18-2011, 07:25 AM   #2 (permalink)
View dorman68's Photo Gallery
I would start by checking your fuses and relays for the fuel pump.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 07-18-2011, 06:15 PM   #3 (permalink)
i just did that today and everything is good
Old 07-18-2011, 07:57 PM   #4 (permalink)
vic benson's Avatar
Gameroom cash: $142500
View vic benson's Photo Gallery
did you check the seal on the gas cap??
vic benson is offline   Reply With Quote
Old 07-19-2011, 06:24 AM   #5 (permalink)
I would check to see if you are getting power to the fuel pump, I would hook a volt meter to the connector to check for power. If you are getting power I would blame the fuel pump, if you don't get any power I would check the wiring leading to the fuel pump.
Old 07-19-2011, 07:41 PM   #6 (permalink)
dorman68 I would check to see if you are getting power to the fuel pump, I would hook a volt meter to the connector to check for power. If you are getting power I would blame the fuel pump, if you don't get any power I would check the wiring leading to the fuel pump.
i got power to the fuel pump. i removed the fuel pump to make sure i had everything in the right place and noticed that the o-ring fuel pump was not seated right. i replaced it and got a good stream of fuel coming out of the fuel line before the fuel rail. do not know the exact pressure due to me forgetting the pressure gauge at work. checked the injectors and 3 out of the 4 are pulsating slowly and 1 is pulsating normally.
Old 07-20-2011, 06:55 AM   #7 (permalink)
At this point I would put a pressure gauge on it. The only other thing that comes to my mind is faulty injectors or the injectors not firing properly because the ecm is not commanding them for whatever reason. It might be worth your while to have the car scanned for codes and the injectors professionally cleaned and flow tested. My local machine shop does this, perhaps there is one in your area that does as well.
Old 07-26-2011, 07:52 PM   #8 (permalink)
i got good fuel pressure when the pump is running but when the pump shuts off the fuel pressure goes away. replaced the fuel injectors yesterday and got working ones and the PCM is good. any ideas or suggestions?
Old 07-31-2011, 12:14 PM   #9 (permalink)
View ElDominio's Photo Gallery
Did you check the timing belt???
ElDominio is offline   Reply With Quote
Old 07-31-2011, 06:56 PM   #10 (permalink)
it has a timing chain and it is in good shape for 165K. has a little slack in it but nothing bad enough to make it jump timing.
Old 08-01-2011, 10:18 PM   #11 (permalink)
thanks for everyone's suggestion but i had to break down and tow it to the dealer to get it fixed
Old 08-02-2011, 06:39 AM   #12 (permalink)
Let us know what happens. I hope the repair bill isn't too bad.
