Originally Posted by dorman68
x2 I agree. It sounds like your engine is running too cool due to your thermostat being bad (stuck open).
I discovered that I had a wire next to the radiator hose at the block plugged in backwards. It's over by the air filter. This all happened before I realized that the thermostat was at the end of the lower radiator hose. I was looking for the thermostat on the upper radiator hose and disconnected a wire at the block because I thought I would need the room and didn't want to damage the sensor while working on the thermostat.
After plugging the connector in the correct way (lined up with the notch), the blue light and red light and check engine light all stayed off for a day. Now I have the red light coming back on and I have to turn on the heater on hot and full blast to cool the engine down and make that silly red light shutoff.
Now I am stumped again. I was trying to avoid pressure tests because I am not very knowledgeable in that area of engines. I am willing to learn if I need to. I guess the next thing to do will be to test the electric radiator fan. I am not sure when but I remember seeing the fan turning slowly a couple times. That fan is either on full blast or off, right? Is there a variable speed that I am not aware of?
I am back at work at my day job but I am starting to feel like a full-time auto mechanic because I am working on a '91 Toyota pickup and 2000 Echo at the same time pretty much - I am being stubborn and not using my vacation for this stuff -using all of my free time in the morning and at night to troubleshoot and work on cars. I am somewhat of a geek and enjoy a challenge but now I want to get to the bottom of this stuff and have two good running vehicles to share with my sons before winter.
