2003 Echo Engine light blinks at ecceleration, shudders, idles rough - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-15-2011, 08:01 AM   #1 (permalink)
View roxy1rose's Photo Gallery
Canada 2003 Echo Engine light blinks at ecceleration, shudders, idles rough
My car is a standard and was working fine not indication of any troubles. Stopped and pumped $20 gas.
Started to drive and car starts running rough especially at low speeds. Going up hill is brutal. Engine light flash when trying to eccelerate, slow getting up to speed, shudders- not a lot of power, once up to speed engine light turn off. Press the gas to go up hill- engine light comes back on and it begins all over, it also sounds like it is not running on all cylinders.
Is there any suggestions: fuel pump, fuel injection...spark plugs and wires? Something more serious
roxy1rose is offline   Reply With Quote
Old 08-19-2011, 09:37 PM   #2 (permalink)
thebarber's Avatar
View thebarber's Photo Gallery
check the engine codes....but flashing light usually means misfires
sounds like your engine is dying.
thebarber is offline   Reply With Quote
Old 08-20-2011, 11:06 AM   #3 (permalink)
View thetut's Photo Gallery
Try the simple things first. You say this started after you filled up. The gas station tank may have been contaminated with ground water. Pour in a couple of bottles of gas line antifreeze and see what happens.
thetut is offline   Reply With Quote
Tags
ecceleration, echo, engine light, fuel injected, idles rough
