Vapors leaking into cabin - 2001 Echo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-06-2011, 05:18 PM   #1 (permalink)
View thecommodore's Photo Gallery
USA Vapors leaking into cabin - 2001 Echo
A couple of weeks ago, I smelled gasoline vapors in the cabin of my '01 Echo. The check engine light had come on a couple of days earlier. I checked under the hood and found a hose leading from what I think is the purge control valve had come loose. So I reattached it, and it was fine for awhile. I had the car scanned to see what brought the CE light on, and a number of codes came up - one for the rear O2 sensor, and a few EVAP codes that I can't remember.
A few days after I reattached the hose, something else started leaking into the cabin. It wasn't gasoline, but I was starting to feel light headed while driving. Figuring that couldn't be good, I had it looked at again by a friend of mine. He isn't sure, but he thinks it might have something to do with the charcoal cannister. He also suggested getting a new gas tank cap, so I did. There was no leakage for a day, and then one more time, something else I couldn't determine started seeping through. More light headedness, etc.
Does anyone have any idea what is going on, or am I in a suicide machine?
Thanks!
thecommodore is offline   Reply With Quote
Old 09-11-2011, 09:52 PM   #2 (permalink)
View ET ECHO's Photo Gallery
Getting light headed is not good. It could be carbon monoxide. Check your exhaust system and make sure it is in good repair. You may get a CO detector and check for the gas. It is odorless but exhaust fumes are not. CO is insidious and not to be taken lightly. Just a thought.
ET ECHO is offline   Reply With Quote
