code P0012 O5 Echo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2011, 06:20 AM   #1 (permalink)
jambo101's Avatar
View jambo101's Photo Gallery
code P0012 O5 Echo
Check engine light coming on in the past few days, scangauge says code P0012, any one else have this problem and what did it end up to be, car is running normally...
If it does turn out to be a "Camshaft Position sensor" is this an unplug the old sensor, plug in a new sensor type of job?
jambo101 is offline   Reply With Quote
Old 10-07-2011, 08:51 AM   #2 (permalink)
jambo101's Avatar
70+ views in under 2 hours..
Old 10-07-2011, 09:04 AM   #3 (permalink)
View ET ECHO's Photo Gallery
I don't have info on the 05 Echo. On the 02 Echo the Cam Position Sensor is on the drivers side of the engine hidden by the Air Filter box. Just one electrical connector and one bolt. Bolt torque 71 in lb. Never had a problem with it.
ET ECHO is offline   Reply With Quote
Old 10-07-2011, 09:31 AM   #4 (permalink)
jambo101's Avatar
Sounds fairly easy, i cleard the code and now i'll see how long it takes to come back on.
Wife said it started happening right after she filled the gas tank, i re tightened the gas cap and am now hopping that was the problem.
Old 10-07-2011, 10:45 AM   #5 (permalink)
Stevo_Echohb05's Avatar
Gameroom cash: $126305
View Stevo_Echohb05's Photo Gallery
Check the Oil Control Valve
Stevo_Echohb05 is offline   Reply With Quote
Old 12-19-2011, 09:55 AM   #6 (permalink)
View Harris's Photo Gallery
p0012
First i had p0010 diagonistic ecm now p0012 shows up clear for a day then shows up. Now what.
Harris is offline   Reply With Quote
