Hello,
My great 2001 Echo is acting up for the first time in 11yrs!.. This weekend I decided to have my mechanic change the manual transmission fluid and do a general inspection of the vehicle. He found nothing wrong. I decided that before embarking on a long trip, that I would change the oil/filter, flush the radiator and put new antifreeze, change the airfilter, replace the alternator belt, added a small bottle of Lucas complete fuel system and a new battery. I was proud of my DIY performance except that the next day the engine light came on! I took it to AutoZone where I purchase all the supplies and battery and they came up with CODE P1349 which I researched and found out about VVT(variable valve timing) malfunction. Some of the reasons for this malfunction are: low fuel pressure due to clogged or bad injectors..... Fuel pump regulator....camshaft malfunction
or ECU (engine control unit) problem. I have no idea which one of these is the problem but I can tell you the following:
This morning the light was off then ten or fifteen minutes later it went on and at the same time the iddle got much faster for about two or three minutes, (in other words the engine was running faster even when I took my foot off the accelerator) and then came back to normal. Later on the light was off again followed by the same sequence of events. Then at one point later I could tell that the the engine was running fast again for a couple of minutes.
Can someone help me decide what to do to get rid of this problem. Is it a DIY project?
I would greatly appreciate your help
