Timing Belt Squeaks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2011, 09:10 PM   #1 (permalink)
View Dj Unbalanced's Photo Gallery
Timing Belt Squeaks
Hi forum. My name is Moe. I have had a 2001 Toyota Echo fro 6 years now. i recently put in a new sound system in. and everytime i stop at a light or slow down my timing belt squeaks. i was wondering should i buy a new alternator, timing belt or both.
Dj Unbalanced is offline   Reply With Quote
Old 11-22-2011, 09:11 PM   #2 (permalink)
ALSO AVAILABLE IN SOBER
Zembonez's Avatar
Gameroom cash: $619431
View Zembonez's Photo Gallery
Welcome.
More than likely the belt you hear is the drive belt... not a timing belt. Might be time for a new one!
Zembonez is offline   Reply With Quote
Old 11-22-2011, 09:18 PM   #3 (permalink)
Originally Posted by Zembonez View Post
Welcome.
what is the difference between a Drive and a Time belt?
Old 11-22-2011, 09:20 PM   #4 (permalink)
Zembonez's Avatar
A timing belt is hidden from view normally and runs the camshaft. Drive belts are visible and run things like alternators and ac compressors, etc.
Old 11-22-2011, 09:33 PM   #5 (permalink)
if i go to a regular mechanic and say that i need a Drive belt change, will they know the difference or will the change the timing belt?
Old 11-23-2011, 07:42 AM   #6 (permalink)
View 2005RS's Photo Gallery
I normally do that sort of stuff myself, but when I do go to a mechanic, I tell them what the symptom is and ask them to fix that. That way, if the problem is a loose belt, they can adjust it and you're good to go. If you specifically ask them to change the belt, they will whether you need it or not.
As an aside: I believe the belt driving your ac, alternator, etc. is called a serpentine belt. The echo doesn't have a timing belt, it's a chain. If your mechanic is suggesting a timing belt change in your echo for any reason, find another mechanic.
2005RS is offline   Reply With Quote
Old 11-23-2011, 06:38 PM   #7 (permalink)
View ET ECHO's Photo Gallery
Click here for belt info.
BTW I HATE THE ANNOYING JAGUAR AD THAT KEEPS POPPING UP ON EVERY PAGE.
ET ECHO is offline   Reply With Quote
The Following User Says Thank You to ET ECHO For This Useful Post:
denman (11-25-2011)
Old 11-24-2011, 08:29 PM   #8 (permalink)
RAM-Driver
denman's Avatar
View denman's Photo Gallery
Canada
The "alternator belt" is a better term since there's also a power steering right there. Try tightening the alt belt a bit; I like mine to chirp occasionally so I can be sure it's not too tight and strain the bearings; but if that doesn't keep it from being too annoying then it's change time as has been said. But carry your old one as a git-ya-home spare. And if you change it yourself you'll find (if it's like mine) the PS belt OUTSIDE the alt belt so both need to come off. Try leaving your PS belt off and see how you like it. I did and like the steering feel much better
2000 Echo, 200,000kms, aftermarket cruise control (AudioVox CCS-100), Intelligent Battery Guard (CTC), Sirius Satellite Radio, Scangage II, Garmin GPS, synthetic engine and gearbox lubes , Silicone Brake Fluid, Power Steering belt removed, delighted with the "tiny perfect car"
denman is offline   Reply With Quote
Old 11-25-2011, 07:51 AM   #9 (permalink)
that power steering belt is a pain to change so you may as well get a new one while you're at it. Personally, I found the steering quite heavy without power assist. Then again, I do like to grind a little rubber off the tires on corners
Old 11-25-2011, 10:37 AM   #10 (permalink)
Billiam's Avatar
Gameroom cash: $205825
View Billiam's Photo Gallery
FYI...the 1NZ engine has no timing belt.
If you want to enjoy your car....stay off the internet.
Billiam is offline   Reply With Quote
Old 11-25-2011, 02:06 PM   #11 (permalink)
RAM-Driver
denman's Avatar
Canada
VERY topical link, thanks
Old 11-27-2011, 04:42 AM   #12 (permalink)
jambo101's Avatar
View jambo101's Photo Gallery
Echo's dont have timing belts they have timing chains and usually last the life of the engine needing no maintenance .The squeal you are hearing is coming from the accessory belts, perhaps time to change them..
jambo101 is offline   Reply With Quote
