blower problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2011, 11:07 PM   #1 (permalink)
View iznogoud's Photo Gallery
Canada blower problem
since yesterday i hear the motor blower running but the cabin air is cold. The coolant level is ok and radiator fan is working properly. I don't know which part failed? the blower motor or the resistor
Anyone have an idea? thanks
Toyota Echo 2003
146 000 km
Motor blower already changed 2 years ago by a used one.
iznogoud is offline   Reply With Quote
Old 12-08-2011, 10:53 AM   #2 (permalink)
RAM-Driver
denman's Avatar
View denman's Photo Gallery
Canada
Assuming you can feel moving air, ie blower working, I'd look at the temperature controller. It could be as simple as a cable or vacuum line off the valve lever. Follow the heater hoses toward the firewall to find the valve. If it's not there reply and I'll go look at mine..
2000 Echo, 200,000kms, aftermarket cruise control (AudioVox CCS-100), Intelligent Battery Guard (CTC), Sirius Satellite Radio, Scangage II, Garmin GPS, synthetic engine and gearbox lubes , Silicone Brake Fluid, Power Steering belt removed, delighted with the "tiny perfect car"
denman is offline   Reply With Quote
Old 12-08-2011, 09:09 PM   #3 (permalink)
Dave's
Gameroom cash: $124850
View Dave's's Photo Gallery
If the blower is circulating air through the cabin as it should and it runs at all speeds then the blower and resistors (which provide the different speeds) are not the problem. You can have the right coolant level and the radiator fan working but if there's a valve which keeps coolant from cycling through the heater core you'll need to manually open it for a temp fix and then repair the problem. If it's not the valve then it's probably a defective thermostat. It may be stuck open or just a weak spring allowing it to open too soon. Check your temp gauge to see if you're reaching a normal operating temperature.
Dave's is offline   Reply With Quote
