My Echo 2005 70K make grinding noise at startup and at low speed. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2012, 03:04 PM   #1 (permalink)
View hengone's Photo Gallery
Can someone help me to diagnostic the noise coming from my Echo 2005? 70K miles. I took to the dealer twice and spend a total of 500$ but the noise still there. The dealer changed the drive belt , new brake pad and clean the rear drum and adjustment. The noise occurred at start up and sometime at low speed below 10mph. The noise increase then stops after 6 second. Anyone have this problem before???
http://youtu.be/XETWXYLA1-U
hengone is offline   Reply With Quote
Old 01-06-2012, 06:05 PM   #2 (permalink)
Newbie One Kanobi
ECHOKnight2000's Avatar
Gameroom cash: $664359
View ECHOKnight2000's Photo Gallery
I was going to say maybe transmission but it doesn't sound that way. I honestly couldn't tell you. I'm sorry to hear you spent that money already, i think you got ripped off.
Live faster than the speed of fear
ECHOKnight2000 is offline   Reply With Quote
Old 01-06-2012, 06:39 PM   #3 (permalink)
Gameroom cash: $819301
View zythr's Photo Gallery
Poor OP, got "screwed"
zythr is offline   Reply With Quote
Old 01-08-2012, 09:26 PM   #4 (permalink)
toyota 2005 noise continued
Hi I uploaded another video of the noise coming from my Echo. The noise is near the Alternator and at the drive belt.
http://youtu.be/ZItAcF58Dq0
Old 01-21-2012, 05:47 PM   #5 (permalink)
View ericlp's Photo Gallery
wow, that's annoying. Sounds like it could be a pulley or possibly the alternator bearing going out? I guess if something seizes up say goodbye to that new belt. too bad you didn't rev it up a little to see if the noise changes?
ericlp is offline   Reply With Quote
Old 01-28-2012, 02:25 AM   #6 (permalink)
1MZ powered MR2
Jason.MZW20's Avatar
Gameroom cash: $227050
View Jason.MZW20's Photo Gallery
Could be a bad power steering pump. They tend to make awful noises. Since this isn't a serpentine belt drive system, you can remove each drive belt to see where the noise is coming from. At least, that's what I would do if I were a tech working on your car.
Here's a quick test: Turn the A/C on to put extra load on the crank, water pump, A/C and alternator belt. If the noise worsens, you can suspect an issue somewhere on that belt. The P/S pump is a little more difficult, but you could quickly turn it lock to lock. If it's difficult to turn and the noise increases, you've found a prime suspect.
Bad bearings also make pretty nasty noises. Usually, a bad alternator will start to whine first, and the Denso alternators actually use pretty decent bearings. The brushes will wear away before bearing failure, I'd think. But, you never know.
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
Jason.MZW20 is offline   Reply With Quote
The Following User Says Thank You to Jason.MZW20 For This Useful Post:
ECHOKnight2000 (01-28-2012)
Old 01-28-2012, 06:35 PM   #7 (permalink)
RAM-Driver
denman's Avatar
View denman's Photo Gallery
Canada
Sure sounds like a spun bearing, .... another quick test is spritz some water on the belts while idling; if it's just belt squeal it'll stop briefly until it dries. Otherwise as suggested, load up one belt then the other. Or better, take the PS belt off and run it. If the noise stops the leave the belt off. I took mine off a year or so ago and really like the "steering feel" I now have ...
2000 Echo, 200,000kms, aftermarket cruise control (AudioVox CCS-100), Intelligent Battery Guard (CTC), Sirius Satellite Radio, Scangage II, Garmin GPS, synthetic engine and gearbox lubes , Silicone Brake Fluid, Power Steering belt removed, delighted with the "tiny perfect car"
denman is offline   Reply With Quote
