[Echo 2004] Car Stuttering
Hi, please bear with me for my long essay, just looking for some advice here on what I could check. Today I took my friend to his mechanic and the drive to and back (30 mins or so combined) was fine. I turned on the AC on the way back. Then we had a 15 minute stop off, then when I restarted the car, put on the AC, then tried to reverse I noticed it was struggling a bit to go back.
Anyway I didn't think much of it until I went into first gear, and noticed it was stuttering a bit. The same happened in second and third. So I took off the AC (assuming that it was drawing too much power) but the car was still stuttering.
We thought it might be one of a few things: spark plugs, MAF sensor needs to be cleaned, fuel pump on it's way out, fuel filter needs to be replaced.
I checked the spark plugs (didnt remove them btw, just removed the connections one by one and listened for a difference in the engine) and they seemed to be ok. We took out the MAF sensor and it definitely needs to be cleaned. Don't know why that would be the problem though as the car was working fine until we stopped that last time. Didn't do anything with the fuel pump or filter.
Anyway took it to the mechanic, I told him I'd only driven 13000 km since the last spark plug change so he ruled that out. He then wanted me to do a computer test and bring back the results.
In any case we ended up back at my friend's mechanic (as he called us in) so I asked someone else there. He had a look at things took out some hoses when the engine was running (replacing them within a second or so) and basically told me it's the spark plugs.
Since they're relatively cheap to replace I went and got new ones, haven't stuck them it as yet though. Are there any other possible reasons as to why things may have happened they way they did?
Edit: Forgot to mention, the Scangauge II shows no error codes, yet the mechanic insists I do a proper computer test (what's the difference btw?).
