yeah and if your gonna do all that, might as well check suspension (tie rods, struts, etc...etc...) Also, might want to replace the cv's ... or at least look at lubing them up and changing out the dust boots.
Nothing worse then spending several thousand dollars on a new transmission just to have to turn around and spend another grand on axles ... since the parts are cheap is the work of getting them out that's costly.
But like Denman states the echo really is a great little car that gets 40MPG and as far as I'm concerned it can't be beat. Sometimes it's well worth fixing something that could go for a few hundred thousand more miles and save you thousands in gas alone!
