Replaced battery & alternator in 08 yaris still not working - Toyota Nation Forum : Toyota Car and Truck Forums
#1 Old 11-25-2012, 09:27 AM
Quoted: 0 Post(s)
(Thread Starter)
I just recently replaced my alternator and battery in my 08 Toyota yaris and it's still not holding a charge. My blinkers, radio, and heating and air won't come on , also my wheel is hard to turn and in order to shift gears I have to push down the white button near the shift stick. I'm so confused as to what else could be going wrong and my mechanic can't seem to figure things out my last resort is the dealership but I'm thinking that would be expensive if anyone has any suggestions please reply thank you.
Daniellelashun23 is offline
#2 Old 11-25-2012, 05:42 PM
Newbie One Kanobi
ECHOKnight2000's Avatar
Quoted: 288 Post(s)
Idk much about this stuff but do you think it could be a bad fuse or short?? It might be shorting the alternator or battery??? That's really bizzare.
Some question if big business is too big to fail. In reality government is too big which is why its failing.
ECHOKnight2000 is online now
#3 Old 11-27-2012, 01:23 AM
Quoted: 3 Post(s)
hmmm, check the alternator fuse it's suppose to be near the air box. 100 amp fuse or something like that.
I'd also check the grounding wires that ground the alternator ... It could be loose or damaged. It's called a grounding strap. Check the ground on the battery make sure it's ok.
Other than that... you could take it to someone that know how to check the wiring since I'm sure it's something that is loose or broken. You need to trace the main wires that run from the alternator to the battery.
ericlp is offline
#4 Old 11-27-2012, 02:46 AM
Ninja-rator
RningOnFumes's Avatar
Quoted: 2 Post(s)
So your new battery is dead again? When it was fresh, were all those electrical components working including the power steering? If it's a yes, go with ericilp's advice.
Sounds like the car was taking juice purely from the battery. Check the alternator to make sure it's doing its job even if it's new. Then start with tracing the wires from the alternator towards the car checking any grounds and fuses as you go.
RningOnFumes is offline
#5 Old 01-03-2013, 11:27 PM
Quoted: 0 Post(s)
Yes, the guy above me is correct. The battery has a protection fuse. Its either on the positive battery terminal (your lucky) or its in the fuse box which requires you to disassemble, its not hard but not for the inexperienced. When i worked at Toyota they were only 10$ and always in stock.
CoUpONs420 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Yaris, Vitz and Echo Forum
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Toyota Nation Forum : Toyota Car and Truck Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
If you do not want to register, fill this field only and the name will be used as user name for your post.
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
