5E-FE ECU on a 3E-E - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2004, 11:03 AM   #16 (permalink)
View LukeMasters's Photo Gallery
So far this is how i was going to do it :
http://www.homemadeturbo.com/tech_pr...ion/index.html
it did not seem to complex. Nor did it say anything about it being dangerous
It's not how fast you drive, It's how you drive fast.
LukeMasters is offline   Reply With Quote
Old 08-24-2004, 12:27 PM   #17 (permalink)
View kene's Photo Gallery
IT is deangerous if you do not use a fuse or a circuit breaker!!...thats all im saying..use a fguse or a circuit breaker. so you dont short everything out, burn your circuitry, possibly cause the batt to explod or start a fire. im not saying dont do it. just use a fuse or circuit breaker on the positives line. and make sure you use the right amperage fuse. for the fuse you cannot exceed the max amp rating that is running thru the battery. Or else you fuse will not blow if there is a problem and it will be as if there was never a fse installed.
also look at the last picture(the all chrome box) on tht page. you can see that the guy installed a fuse/circuit breaker.
kene is offline   Reply With Quote
Old 08-24-2004, 12:29 PM   #18 (permalink)
it is very dangerous if you dont do it right. think about this. would you take a car battery and put a metal pipe over the positive and negative ends? more than likeley it will explode if done long enough. this is what can happen if you don not install this setupo using the proper procedures.
Old 08-26-2004, 01:51 AM   #19 (permalink)
Ok, so the Battery is in the back, The ratio is better but not great, and i will be heading to a scrap yard tomorrow to see if i cant find a nice little paseo ECU, he he he.....
Old 08-26-2004, 01:55 AM   #20 (permalink)
were you able to hook up a fuse/circuit breaker to it?
Old 08-26-2004, 01:57 AM   #21 (permalink)
Tryed it, but i only had 25 and 35 amp fuse so they all died, i will get a 50 or 100 amp tomorrow. But i had everything check by a mecanic to make sur everything is ok
Old 08-26-2004, 02:07 AM   #22 (permalink)
you may need toget something that would be used for high power applications. remmamber the average tercel batt has 425 cranking amps.
Old 08-26-2004, 02:11 AM   #23 (permalink)
yeah i will look into it, worst comes to worst i might blow a few more fuses...
I'm starting to get nasty ideas after seeing that Tercel with the 4e-fte with the T3/T4 turbo....
Old 08-26-2004, 02:16 AM   #24 (permalink)
here you go
read the first post...try that style of fuse.
http://66.102.7.104/search?q=cache:3...location&hl=en
heres a pic of the fuse.(these are 150amp and 200+amp ANL fuses)
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
heres the fuse holder
http://cgi.ebay.com/ws/eBayISAPI.dll...716366519&rd=1
Old 08-26-2004, 10:34 AM   #25 (permalink)
I will look into the fuse holder and fuse today, you say 150amps? people have started telling me 50, 100, 450. So i'm confused with that...
Someone ask for the safe route i used, sorry for not answering before, i just saw the post. I passed it on the passenger side. I had a hole in my firewall ( i think it was for AC, wich i do not have on my car ). So i passed it in that hole, then i removed the little platic covers under the door, and passed it there same thing for the rear, and to get in the trunk i passe at the same place the break light wire passe but on the passenger side.
The wire take 5 minutes to pass, it was very easy. Maybe one important thing i would guest for newbies reading this, when in the engine bay do not let your wire touch anything that will get hot ( engine, exhaust manifold... )
Old 08-26-2004, 12:42 PM   #26 (permalink)
i would say buy a 100 ANL fuse and a 150ANL fuse. keep both in your car. use the 100 first. if for any reason it blows down the line, check and exsure that the positive is not grounding out on the chassis. after that then tryh the 150ANL. once you have the 150ANL get a 200 ANL just in case the 150 blows because the system has too many amps running thru it. basically trial and error.
Old 08-26-2004, 10:37 PM   #27 (permalink)
Back to the ECU swap wich was the original subject. I'm gonna have to put it on old... i tough i could get one used, for about 30-50$ guess not, used, they go for 150 bones. Money i dont want to spend on a upgrade, that MIGHT give me a little more power... So i'm still looking for a cheap one... maybe from a scrap Paseo or something but i guess it's not gonna be any time soon
Old 08-27-2004, 12:28 AM   #28 (permalink)
keep looking on ebay...sometimes you can find em for 20$
