2000 Echo - poor braking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-13-2004, 08:34 PM   #1 (permalink)
View emi323i's Photo Gallery
I noticed braking performance on my echo is really bad under heavy braking... i just can't get the front wheels to lock up.
pedal is firm
i bled all 4 corners - twice
new brembo replacement rotors w/ oem pads
the car slows down quite well under normal driving
if i stump the pedal, it feels as if i just touched it.... as if the rotors were slippery. there's no way i can lock the front wheels, unless it's raining.
please help... thanks
'00 toyota echo
emi323i is offline   Reply With Quote
Old 09-14-2004, 09:23 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
how long ago did you put the rotors on, and does the car have ABS ?
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 09-15-2004, 07:43 AM   #3 (permalink)
No ABS, I replaced them about a month ago.
'00 toyota echo
Old 09-15-2004, 08:32 PM   #4 (permalink)
dougone's Avatar
View dougone's Photo Gallery
Might want to try flushing the whole brake fluid!
Lord give me patience - Right bloody now!
dougone is offline   Reply With Quote
Old 09-16-2004, 07:26 AM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
when you installed the new rotors, did you wash off the anti-rust film they come with? If not it's possible that the slippage this would allow may have boiled the brake fluid. During a month the film would be worn off, a bleeding may take care of the problem.
雄のハヤブサ
Old 10-07-2004, 06:48 PM   #6 (permalink)
i just found out that toyota revised the brakes and replaced the 235mm rotors with 255 mm rotors in 07/2000, so the first echo's that came out had smaller rotors... that sucks, because noone makes brake pads for those echos I bet... not kvr, forget brembo, hawk doesn't even list the echo at all.
I remember the oem replacement brembo's i had on my 3 series had the same problem. perhaps that's what the problem is, altho it seems unlikely. I shou8ld perhaps invest into oem rotors.
'00 toyota echo
Old 10-08-2004, 05:13 PM   #7 (permalink)
cuteroxygurl's Avatar
View cuteroxygurl's Photo Gallery
I have an '01 Echo. My brakes lock badly. I hate it because then I skid. But at least I stop... eventually.
Michelle
cuteroxygurl is offline   Reply With Quote
