radio - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2004, 06:07 PM   #1 (permalink)
View theman86_2's Photo Gallery
radio
I found about 11 volts in my radio fuse so i checked it out and found a couple of loose and disconneced wires, i reconnected them and voltage went down to .66 volts and the problem is i cant seem to find a good ground anywhere that will zero the voltage. Do any of you know where/what your radio is grounded to?
theman86_2 is offline   Reply With Quote
Old 10-03-2004, 01:42 AM   #2 (permalink)
anyone?
Old 10-03-2004, 02:55 PM   #3 (permalink)
View piggyfinndude's Photo Gallery
i don't know where the "Real" spot is for the ground, but i Just screwed it on with the metal "Casing" that supports the radio and that made a ground. Remember, anything that touches the chassis will be a ground.
Simple terms.....wrap the wire/buy a ring clamp on it and screw that on the screw and it'll ground.
Works for me...
piggyfinndude is offline   Reply With Quote
Old 10-03-2004, 04:42 PM   #4 (permalink)
Ok because i wrapped it around a center console screw and it touches the metal part of the chassis but it seems like a weird place to put it and i wonder if it's a good enough ground. I am not good at all with wiring diagrams.
