Brake pedal goes to the floor when the car is on? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-16-2004, 10:01 AM   #1 (permalink)
View brando's Photo Gallery
The car (91 Tercel) has been sitting for about a month now. Drove fine last time I had it going. Went to play with it today, and the brake pedal holds pressure when the car is off, but when you turn it on, it goes right to the floor. It does still have a bit of pressure left to it, but it locks up what seems to be 1 or 2 tires.
What does it sound like? The brakes need to be bled? Brake cylinder? Any ideas?
brando is offline   Reply With Quote
Old 12-16-2004, 02:12 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
sounds like a bad booster.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 12-16-2004, 02:54 PM   #3 (permalink)
got the call back from the mechanic.
Apparantly there is a leak in 2 of the hoses... the lines cracked in the cold weather.
So, as of right now, I need to replace all the lines, all the brakes, and the gas tank... this sucks.
Old 12-16-2004, 10:27 PM   #4 (permalink)
View theman86_2's Photo Gallery
thats crazy i had the same problem and i changed rotors (which were still in spec) and pads (which had a ton of meat on them) but the problem went away. i can't figure out why it acted like it had a bad booster but ...
theman86_2 is offline   Reply With Quote
