dirtweed got a Q for ya - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-25-2004, 11:08 PM   #1 (permalink)
The Gardener
Location: depends on which state takes my driving priveledges
View Jonsblckhwk's Photo Gallery
what kind of frame bracing are you going to use?
and what are your opinions on frame bracing? like is a full tube chassis stronger than a roll cage against torsion as i dont want to bend my frame like the guy with the 20v did
http://tercel4wd.com/invision/
http://www.northeasterntuners.com
http://www.socel.tk
http://board.tercelonline.com
http://www.torontopaseoclub.com
Jonsblckhwk is offline   Reply With Quote
Old 12-26-2004, 06:58 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
haven't heard about the 20v guy, show me a link please. I'm going to tie the lower chassis together where the lower control arms mount, and have a strut tower brace that will tie in the firewall also. As for bending I really don't know. At least I'm honest! In all seriousness though,the torque will be distributed through the CV axles. The only real pulling should be an effort to twist the engine/trans. I have a bar that mounts front to rear similar to the celica setup. 2 motor mounts on it and the bar is made of twin square tube steel rails attached every 6". I can't see that bending very easily myself. The front of the bar mounts under the radiator and since that metal was so thin I reinforced there also. Eventually I'll create some type of polyurethane mounts that I'll be happier with.
Frame bracing and tube frames come into play on a RWD setup. There is so much between what produces the power and what puts the power to the ground. The rear axle wants to twist in 2 directions and the engine/trans want to twist in another 2 directions. See the problem? The rear spring mounts have to be solid. On our cars the rear axle just holds the bumper off the ground basically. (I realize it can't be soft before the flaming starts here) So therefore there's not a lot of torque absorbed by our cars.
There will however be a much stronger pull on the front to squeeze together underneath. As the front tires attemp to launch they are held back by the bearings and hubs to move the small weight. That is the main purpose I feel the need to tie the underside together.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 12-27-2004, 12:09 AM   #3 (permalink)
The Gardener
http://tercel4wd.com/invision/index....=ST&f=2&t=531&
there is a post of the guy giving some valuable info out and the guy that is posting is the guy that did it(20vtercel)
http://www.socel.tk
Old 12-27-2004, 09:29 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
nice
I notice his is 4wd, and by this massive chassis setup he must be off roading. A 4wd has the torsion issues just as a rwd, but not as strong. I have to agree with russkiypenguin though.....
....people SERIOUSLY upgrading their HP and they never have to boost their frames Bent frames come from collisions or REALLY REALLY powerful engines like a 500HP big block.
雄のハヤブサ
Old 12-27-2004, 11:58 PM   #5 (permalink)
The Gardener
i beleive his car was modified to be 4wd/rwd
http://www.socel.tk
