Engine Swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-28-2005, 01:00 AM   #1 (permalink)
RockStar
View stevenj's Photo Gallery
USA Engine Swap
I have a '94 Tercel and my friend "Toyota" was checking out under the hood and said it could fit an engine from a Celica GTS something about vvti. Anyone know anything about this.
stevenj is offline   Reply With Quote
Old 01-28-2005, 04:27 AM   #2 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
Heheh
The best engine for you car is the 4EFTE 1.3 Turbo from the JDM Toyota Starlet GT.
http://www.phoenixtuning.com/
A 2ZZGE (180hp VVTLi) from a Matrix XRS, Corolla XRS, or Celica GTS could also fit, but it would need custom axles, engine mounts, etc...
Dr Tweak is offline   Reply With Quote
Old 01-28-2005, 08:15 AM   #3 (permalink)
Toy-Cel
TdotTercel's Avatar
View TdotTercel's Photo Gallery
yes, it would fit, but there would be ALOT of custom work.....
The 4efte is the best bang for buck as it come stock turbo
you can also fit a JDM 5efhe, or the paseo's 5efe
1992 Tercel DX
JDM 5EFHE, SRI, ACIS, 4-2-1 headers, 2" exhaust, Magnaflow Hi-Flow CAT
TdotTercel is offline   Reply With Quote
Old 01-28-2005, 03:59 PM   #4 (permalink)
View dexter_5000's Photo Gallery
i wanna see someone spend the money on a lift cam engine.
5EFHE Powered JDM Engine
dead 8/23/2005
september 7, 2005 got my new 06 Scion XA
dexter_5000 is offline   Reply With Quote
Old 01-30-2005, 11:34 PM   #5 (permalink)
RockStar
Whats better. 4efte or the 5efhe?
Old 01-30-2005, 11:42 PM   #6 (permalink)
The Mad Scientist
What do you mean by better?
The 4EFTE has more power out of the box and is turbocharged already, so you can install a larger turbo and boost higher without having to rebuild the engine.
The 5EFHE has less power and has higher compression, making it less boost friendly, plus the computer can't handle boost. But, it has a slight displacement advantage, and the internals are quite strong.
My answer: 4EFTE. For the most power, a 5EFHE with a low compression rebuild and turbo would be best. Of course, if you're going to do that much work... you might as well look into the 4AGZE, IMHO.
I hope that helps.
Old 01-31-2005, 11:30 AM   #7 (permalink)
RockStar
Hell yeah that helps, thanks for all the help.
Last edited by stevenj; 01-31-2005 at 11:44 AM. Reason: Found out some info. Didn't need to ask the question
