Tire for 05 Echo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2005, 07:05 PM   #1 (permalink)
View phil's Photo Gallery
Tire for 05 Echo
Hi there,
I am buying a new 05 Echo 5 door hatch next week.
Stock size is 175-65-14, just wondering if 195-60-14 would fit
on there without rubbing. Everything is stock, no mod.
Thanks
phil is offline   Reply With Quote
Old 02-07-2005, 03:33 PM   #2 (permalink)
View 90Tercel's Photo Gallery
I'm not sure about the rubbing part, but I think it should be ok. One thing you should check when you change sizes is if your overall tire size is the same so your speedometer isn't affected. The sizes you indicated are pretty close together, so you shouldn't have to worry about it. It's within like 0.1", which won't amount to much speedwise (you will be going faster than your speedo says, but not noticable).
90Tercel is offline   Reply With Quote
Old 02-08-2005, 09:48 AM   #3 (permalink)
echo_hrs's Avatar
View echo_hrs's Photo Gallery
You're speedo will actually say that you're going faster than you actually are, by about 3%...I have 185/55/15s on mine which are the OEM size for Yaris T-Sports...55 series maintains the correct speedo reading
echo_hrs is offline   Reply With Quote
Old 02-16-2005, 05:38 PM   #4 (permalink)
Just an update, the 195-60-14 fits perfect.
No rubbingat all.
Old 02-17-2005, 11:46 AM   #5 (permalink)
roc
Jedi Knight.
View roc's Photo Gallery
Canada
Here is a link to a site that will give you exact #'s
http://www.miata.net/garage/tirecalc.html
Size matters not! Judge ME by my size do you? Hmmm?
roc is offline   Reply With Quote
