gauges & cooler - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-21-2005, 10:41 PM   #1 (permalink)
View theman86_2's Photo Gallery
gauges & cooler
i am wondering how hard is it to install a tach and volt water and oil gauges in my lil 90 tercel. and also i am thinking of putting a smaller tranny cooler for summer how would i install and where should i install ?
theman86_2 is offline   Reply With Quote
Old 02-21-2005, 11:31 PM   #2 (permalink)
View dexter_5000's Photo Gallery
gauges are pretty simple as long as you get the electrical ones.
5EFHE Powered JDM Engine
dead 8/23/2005
september 7, 2005 got my new 06 Scion XA
dexter_5000 is offline   Reply With Quote
Old 02-22-2005, 10:56 AM   #3 (permalink)
roc
Jedi Knight.
View roc's Photo Gallery
From my experience....Mechanical gauges are easier to install, and less likely for something to happen to them, as it is a much simpler piece of equipment.
As for the external transmission cooler.....I've never driven auto, but from what I've seen....Most people mount them on the outside(front), of the radiator(behind grill), and it should be quite simple to install. Find the rubber lines coming off the transmission. Remove one of the lines, from both ends(trans./rad)use a piece of hose, and run it from the radto the external cooler, and do the same from the trans.(make sure that the hose that you use will work with oil products, as not all hoses will). Before you run the lines, check the instructions to make sure whether there is a specific way the lines have to flow.
Size matters not! Judge ME by my size do you? Hmmm?
roc is offline   Reply With Quote
Old 02-22-2005, 08:56 PM   #4 (permalink)
mechanical is good just not if one of those plastic lines breaks and starts leaking all kinds of fluids in your vehicle.
dead 8/23/2005
Old 02-25-2005, 10:38 PM   #5 (permalink)
i see , i have always heard that the electrical ones are better but im not sure exactly why, on the cooler i wasn't very clear i have a stick and its the original tranny and i figured it would help prolong its life with a cooler but off the top of my head i dont remember seeing lines coming out of it .
Old 02-26-2005, 06:17 AM   #6 (permalink)
coolers are usally for automatic transmissions or very large trucks.
dead 8/23/2005
